Door Lock Problem.
Old Jul 2, 2020 | 02:42 PM
  #21
Default Stay oot not getting in.
What about those rear hinge windows up back of car. They might be cheaper and easier to replace on breaking. If you can crawl in that way.
Old Jul 3, 2020 | 02:26 AM
  #22
Captain Atlantis's Avatar
Good idea goggs. Should be easier to replace and I'm sure ACD will have one. I'll check it out, thanks.
Old Jul 6, 2020 | 02:34 AM
  #23
Problem solved !
In case this helps anyone else stuck with the same dilemma ( dead electrics and can't open door with key ). Probably not recommended but it worked.
Fortunately, there is no under-tray below the front of the engine compartment. I could, therefore, get access enough to put a positive feed on the starter motor and a negative feed on the gearbox ( from my charger ). This put current into the system and I could unlock the doors with the remote fob. I only did this for a split second in case any damage was done ( anyway, the alarm sounded as soon as I made the contact, but stopped as soon as I unlocked the doors ).
Access gained, hood popped, battery charged, everything working normally, so no harm done ( apparently ). Gave the car a good run and all seems fine.
Of course, the parasitic drain will still be there, but that's another job for another day..........
Old Jul 6, 2020 | 04:14 AM
  #24
It may not apply to your 2008 model but see my post at the bottom of this page: https://www.chryslerforum.com/forum/...d-28405/page3/
Old Jul 6, 2020 | 04:28 AM
  #25
Thanks Alan, I'll check this out.
Old Jul 6, 2020 | 04:53 AM
  #26
The AMP on my 2007 model was located behind the plastic panelling above the offside rear wheel. Difficult to see and more difficult to get to. The connection terminals on the AMP had eroded and were causing a short between the power connectors.
Last edited by AlanC; Jul 6, 2020 at 06:03 AM. Reason: Forgot to congratulate you on using your initiative to open the locks
Old Jul 8, 2020 | 07:10 AM
  #27
Thanks again Alan, that AMP will be one to check for sure.
David Brooks
Feb 28, 2018 12:41 PM
quietman
Jul 30, 2017 03:38 PM
Vikingtu
Aug 2, 2015 06:31 AM
john821
Oct 5, 2012 07:12 AM
darlon
Jan 16, 2012 05:00 PM
