Drilled Rotors & Carbon Metallic Pads
Old Sep 7, 2014 | 09:50 AM
Jerry Lewis's Avatar
Thumbs up Drilled Rotors & Carbon Metallic Pads
I had drilled rotors and the Carbon Metallic pads on my previous car Chrysler Voyager and loved the combo, so when my new car needed new front pads I went with what I knew best. I totally agree at first they seem almost ""soft"", but when you get on them they grab just as hard as the stock pads. So for me that was a benefit because I always felt the car kind of shake slightly when first applying the brakes with the stock pads, but with the LUK Schaffer it's a much more gradual grab so it's smoother braking.
Old Sep 7, 2014 | 10:50 AM
TimmyTim's Avatar
I wonder if you are a re-seller of these items?
Old Sep 7, 2014 | 08:40 PM
Hodges710's Avatar
Drilled rotors are not the best way to go, especially in a daily driver. Sure you can be told what ever by someone selling them but you really don't get any gain what so ever in a stock van.
Old Sep 8, 2014 | 06:21 AM
non sports
- coefficient of friction was 21% higher for drilled disks than standard front disks at 340F and higher using 15 brake snubs at 62mph
- a simulated 124 mph fade test showed 37% better brake output for drilled disks, the drilled disks brake temperature was about 150 degrees cooler
performance car
- coefficient of friction was significantly higher for drilled rotors especially at high temperature
- wet braking at high pedal pressure was the same for drilled or standard rotors
- wet braking is not significantly improved by drilled rotors
- pedal force was much more consistent with drilled rotors over the brake temperature range
- that is, to stop at the same deceleration rate, the driver does not need to modulate pedal pressure based on different brake temperatures
- this reduces driver fatigue and improves brake response
see
slotted disks after a quick read round !
Where is the evidence that slotted disks are better or even worse than drilled or non-drilled convection transfer cooling or brake fade ?. There is some evidence that slotted 'chew' 20% more lining material than stock disks, slotted also helps get rid of gas & debris from under the pad. Normal car use slotted seems to be pointless and expensive in terms of normal street motorway cost / benefit whereas maybe and only a maybe track racing will give a benefit where specially formulated coefficient of friction pads are changed each race / event. For me if Porsche, Mercedes and BMW come with OEM drilled rotors, there must be a reason why slotted are not used by these giants of technology research funding.
03 van with rear discs: listed at 281 mm
08 G35 not RWD listed as 319.5 mm
Old Sep 8, 2014 | 01:49 PM
TimmyTim's Avatar
I must admit that we have MTEC drilled and groved with Mintex pads on our GV! And the stopping is fantastic. On my Toyota Celica gt4 ST 205 import I have EBC Turbo Grove and Yellow stuff pads! They are okay once they have warmed up as they are really a track pad...
carid
Jun 14, 2016 07:54 AM
Hodges710
14
Aug 1, 2014 05:57 AM
bdmeyersc
Aug 31, 2013 09:31 PM
aggiejet
Jul 24, 2010 09:22 AM
KYBarrister
Jul 3, 2009 09:21 PM
