EGR Valve
Old Apr 21, 2015 | 02:33 PM
shaky's Avatar
Default EGR Valve
hi guys just wondering if any of you have taken the EGR valve off to clean it , if so is it an easy job and what did you use to clean it,
Old Apr 22, 2015 | 07:45 AM
darkcild101's Avatar
I am going to attempt cleaning with an egr cleaner spray first. I am going to Haggerston Castle this weekend 170miles return trip. I will spray the cleaner just when leaving as it says to go for a good drive after. If that doesnt work will try removing it
Question is where do you spray it in the air intake pipe? Into the box with filter removed or disconnect pipe after filter box
Old Apr 22, 2015 | 11:42 AM
shaky's Avatar
spray it in the air intake before the MAF censor make , mine says get engine warm , leave idle and spray into air intake at one second intervals , keep spraying until can is empty, that's online on wynns site , I am using wynns EGR3
Old Apr 22, 2015 | 01:21 PM
My question is where do i disconnect the pipe to spray into
I am assuming air intake is that pipe next to the engine oil filler cap
Old Apr 22, 2015 | 01:28 PM
shaky's Avatar
look to the left hand side you have the air box , connected to that you have the MAF sensor , disconnect it where it joins the air box and spray it in there so you are spraying it onto the MAF sensor first then through into the air intake
see picture sorry about the size , first time I have done this
Old Apr 22, 2015 | 03:15 PM
silentdub's Avatar
I had to replace mine a while ago, easy job, right up front. It was really rusted bad, so I just replaced it.
You can remove it and clean it, brake or carb cleaner should do it.
Old Apr 23, 2015 | 12:51 AM
shaky's Avatar
mine is right at the back , on a 2.5 crd engine
Old Apr 23, 2015 | 08:09 AM
Sa car as mine. I take it its not easy to remove then
Old Apr 23, 2015 | 11:39 AM
shaky's Avatar
no mate it looks like you have to remove the wipers and the wiper motor housing etc to get down the back of the engine
Old Apr 23, 2015 | 03:02 PM
What I'm interested in for future info, is there any joints renewed on refitting the EGR..
