Electrical problems
Old Feb 28, 2016 | 10:23 PM
Miked's Avatar
Default Electrical problems
My 98 chrysler town and country lxi has intermitted electrical problems. My turn signals and blower motor work at random trac control off light is on the switch for it doesn't work sometimes the trac off light is off and lights around heater flash any ideas of what this is?
Old Mar 3, 2016 | 02:55 PM
Here you still there...Sounds like you have electrical problems that's obvious, but its a resistance problem where the wiring connection/ connector needs cleaned. If you have a fuse box block like the later Voyager check for bad connections underneath.
Old Mar 3, 2016 | 05:41 PM
3G MiniVans are famous for early versions of computer BUS failures [they're not much better now] they all crash. The early version of puters in your Mk van run the powertrain, trannie and even the instrument panel via a CCD [Chrysler Collision Detection BUS] start by having a look at all connectors and fuses you can get to. You might need an old fashioned wire chaser, all and every command on your vehicle runs on just one single pair of wires. Best of luck
jsrccpas
Aug 11, 2019 08:28 PM
Shaun Noonan
Sep 21, 2006 04:39 PM
jmm
Aug 31, 2006 08:05 PM
tad32287
Jul 12, 2006 04:16 PM
Strange_eye
Jun 13, 2006 01:34 PM
