Engine Coolant
Old Mar 16, 2008 | 03:57 PM
Daryl Baines's Avatar
Default Engine Coolant
I have an 02 Chrysler T/C 3.8 engine and cannot see the color of coolant anyone know what color it should be?
Old Mar 17, 2008 | 06:51 AM
tmp03tnc's Avatar
Default RE: Engine Coolant
It is a reddish brown. When my rear heater lines went and it was leaking the first thing I thought it was because of the color was tranny fluid. They look that close.
Old Mar 17, 2008 | 07:14 AM
I wonder's Avatar
what do you need that for?
engine coolant can come in couple of colours. it can be blue, green, red, yellow, white..
usualy, the difference is in chemistry, so that the same colors can mix.
if your coolant is that contaminated that you can not determin it's colour, change it. it should be changed every 2 years anyway and this indicates that it's time for it to go out of the engine.
Old Mar 17, 2008 | 10:44 AM
Reason for knowing the color is I have to add distilled water or coolant and since I cannot see the color just wanted to add the right type of coolant.
Old Mar 17, 2008 | 06:02 PM
Rick99's Avatar
You need HOAT coolant. The Mopar branded stuff is red in color. Zerex sell a version of it that is clear. You can't reall go by color any more. To make matters worse Prestone sells an OAT (not HOAT) coolant that is greenish yellow and that they market as "all makes and models". The stuff does not meet Chrysler's standards, so it should be avoided.
"HOAT" stands for Hybrid Organic Acid Technology and refers to the anti-corosion package.
Old Mar 17, 2008 | 07:36 PM
Rick99
Thank you very much.
Daryl
donnyohs
Nov 14, 2011 11:57 AM
Chrysler300MSpecial
Dec 6, 2009 07:51 PM
offroad360
Apr 29, 2009 04:26 PM
3.3lxbluevan
May 16, 2008 06:30 PM
donnyohs
Oct 2, 2007 11:26 PM
