engine cut out
Hi all,
I was sitting in traffic this morning and the engine spluttered then stopped altogether. I tried it a couple of times to restart but the engine was just turning over. After a while the electrics were going a bit wonky ie rev/speedo went right over and then cam back to normal with engine not running.
The breakdown service guy said it may be ht eegr valve as you can hear the fuel pump rujnning.
TIA
Dave
TIA
Dave
Hi He could hear the fuel pump running? Are you sure and the 2.8 doesn’t have an electric lift pump, could have been the cabin heater he could hear. You want to look at the heater plug on the fuel filter housing (next to the hand prime pump) as these melt so let air into the fault system so it then will but out with fault code P1130 fuel pressure malfunction. There is a modified housing and a repair kit for the heater. The gauges do a sweep when the battery is down but make sure you get it charged up as your alternator wouldn’t fully charge back up a spiral battery that has been flat.
Hi Merlin,
Spoke to the stealer and they confirmed that. If that is the case surely at the last service it would have been noticed that it was beginning to burn and should have been changed. The car is 2 years old and we have it 6 months.
Dave
Dave
Thanks for that response. The stealer changed the part and the engine will not start now. There are no codes showing up on the diagnostics. The recovery truck guy got it started on monday but said he could hear air.
If the wrong fuel is put into the system, what effect will it have?? I am sure diesel was put into it but wide ****ling.
ORIGINAL: dryle
I would think (but others can correct me if I'm wrong) that if you took off the fuel cap, you'd be able to smell the presence of petrol as it's a different smell to diesel.
Dryle, I am curious what happened in the end, could you let us know?
S6Voyager
21
Apr 9, 2013 11:20 AM
