engine cut out
Old Nov 29, 2008 | 02:08 PM
dryle's Avatar
Default engine cut out
Hi all,
I was sitting in traffic this morning and the engine spluttered then stopped altogether. I tried it a couple of times to restart but the engine was just turning over. After a while the electrics were going a bit wonky ie rev/speedo went right over and then cam back to normal with engine not running.
The breakdown service guy said it may be ht eegr valve as you can hear the fuel pump rujnning.
TIA
Dave
Old Nov 30, 2008 | 12:38 PM
Merlin's Avatar
Default RE: engine cut out
Hi
Any change you can post vehicle info as this would help
Old Nov 30, 2008 | 02:12 PM
dryle's Avatar
ORIGINAL: Merlin
Hi
Hi, it is a 06 2.8 crd.
Old Nov 30, 2008 | 04:46 PM
Merlin's Avatar
Hi He could hear the fuel pump running? Are you sure and the 2.8 doesn’t have an electric lift pump, could have been the cabin heater he could hear. You want to look at the heater plug on the fuel filter housing (next to the hand prime pump) as these melt so let air into the fault system so it then will but out with fault code P1130 fuel pressure malfunction. There is a modified housing and a repair kit for the heater. The gauges do a sweep when the battery is down but make sure you get it charged up as your alternator wouldn’t fully charge back up a spiral battery that has been flat.
Old Dec 1, 2008 | 10:38 AM
dryle's Avatar
Hi Merlin,
Spoke to the stealer and they confirmed that. If that is the case surely at the last service it would have been noticed that it was beginning to burn and should have been changed. The car is 2 years old and we have it 6 months.
Dave
Old Dec 1, 2008 | 12:24 PM
Merlin's Avatar
Hi
No, not unless they checked it. Unless you unplug it you can't see it is burnt. On the service you change the filter but don't touch the plug.
Old Dec 4, 2008 | 07:00 AM
dryle's Avatar
Thanks for that response. The stealer changed the part and the engine will not start now. There are no codes showing up on the diagnostics. The recovery truck guy got it started on monday but said he could hear air.
If the wrong fuel is put into the system, what effect will it have?? I am sure diesel was put into it but wide ****ling.
Old Dec 4, 2008 | 07:46 AM
actd's Avatar
ORIGINAL: dryle
Potentially, disastrous - them to check out what's in it immediately. It depends on how much petrol was added, and how much diesel was left in, but I'm assuming that you filled up because you were low on fuel, so there will be a lot more petrol.
I would think (but others can correct me if I'm wrong) that if you took off the fuel cap, you'd be able to smell the presence of petrol as it's a different smell to diesel.
Old Dec 4, 2008 | 08:11 AM
dryle's Avatar
There was just under 1/2 tank and about 10 litres were put in, thing is I am 99% certain it was diesel.
Old Jan 11, 2010 | 04:54 AM
Jacob25crd's Avatar
While rereading all posts I came across this note. I am wondering if a similar thing can happen on a 25 crd? Mine has a diesel fueled heater sitting underneath the car.
Dryle, I am curious what happened in the end, could you let us know?
djr9163
May 18, 2021 11:20 AM
S6Voyager
21
Apr 9, 2013 11:20 AM
skywalker
Jun 1, 2011 12:20 PM
djr9163
19
Jul 3, 2009 07:35 AM
johndun20
Dec 15, 2008 11:53 PM
