engine light
Old Mar 6, 2013 | 01:05 PM
marcnbex's Avatar
Default engine light
i have a 2002 gv 3.3 v6 and the engine light came on when i started up this afternoon looked in handbook and says about loose caps? fuel quality? or servicing? help please
Old Mar 6, 2013 | 01:30 PM
Raptor 07's Avatar
May be as simple as tightening your fuel fill tube cap or maybe not. You'll have to have the codes read with a scanner or you can cycle the key from off to on three times within 5 seconds, leaving it on and read the codes off your odometer.
Old Mar 7, 2013 | 02:41 AM
marcnbex's Avatar
i done that the codes i have are p168.5 p168.4 p013.5
Old Mar 7, 2013 | 02:53 AM
marcnbex's Avatar
got 3 codes p168.5 p168.4 p013.5
Old Mar 7, 2013 | 05:09 AM
travelmad's Avatar
P0135 is related to O2 sensor heater circuit and is probably the cause of the light
Old Mar 7, 2013 | 06:50 AM
marcnbex's Avatar
how easy is it to replacement the part have searched it and says about lambda sensor on exhaust nearest to engine.
Old Mar 7, 2013 | 01:00 PM
Raptor 07's Avatar
Not the greatest video but it will get you there eventually. This should have been a 2 minute video not 7+.
OBD-II Trouble Code: P0135 Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor1)
1685 = SKIM detected an invalid key
4everrunning
Jun 4, 2019 11:30 AM
bgeise
Sep 12, 2014 10:38 AM
qbasicer
Sep 25, 2012 02:58 PM
RobinVA
Jan 5, 2010 10:18 PM
wildcat1944
Sep 28, 2009 10:14 AM
