engine shuts off after refueling
Old May 9, 2015 | 04:52 PM
jsank's Avatar
Default engine shuts off after refueling
I have a 2005 Town and Country with 104,000 miles on it. Once in awhile when I refuel, about 10-15 miles after, it chugs once or twice then the engine turns off. I restart the vehicle and everything is fine. It is slowly starting to happen more often and the mechanics said they didn't find anything wrong. It only happens after refueling and only does it once until I refuel again. I'm concerned because it has happened on the interstate before, and my wife and kids drive it most of the time. Any help would be greatly appreciated.
Old May 9, 2015 | 06:30 PM
Old May 10, 2015 | 06:15 PM
Raptor 07's Avatar
The fix? Replace the fuel tank or don't fill the tank when refueling. There's a valve built into the top of the tank that is supposed to prevent what QinteQ is talking about. Sometimes it fails and won't seal. It's not replaceable without replacing the fuel tank.
Old May 12, 2015 | 01:35 PM
jsank's Avatar
QinteQ, and Raptor 07, thank you very much for the detailed and informative responses. It's not nearly as bad as I was imagining, that is not a hard fix at all.
Old May 12, 2015 | 01:53 PM
You are welcome jsank,
Its an easy cost free fix, just put in a couple of gallons less than fully filled.
Old May 22, 2015 | 07:35 AM
dwkansas's Avatar
Something like this happened to my daughter yesterday with our 03 Chrysler Town & Country. The only thing is that it happened several times. The last time was after she had driven about 50 miles. Could this be the same problem or should there be enough gas used to prevent it? I asked her and she said that she usually adds gas after the pump kicks off in order to get even dollars..
Old May 22, 2015 | 07:38 AM
dwkansas's Avatar
I forgot to say that the first time was right after pulling away from the gas pump.
Ericbo101
Nov 22, 2014 07:58 AM
05pacifica
Nov 20, 2014 08:43 PM
bvanecek
Jan 28, 2012 03:29 PM
seveniron36
12
Dec 29, 2011 11:23 AM
allsho80
Jun 8, 2009 01:35 PM
