entering radio code
Old Jul 20, 2011 | 04:07 PM
blingy's Avatar
Default entering radio code
hi there everyone im new here and need some help.
i bought a voyager le 2.0 r reg last week but the radio wasnt working after some investigation i found that the memory fuse had blown so job done only problem i have now is that i need to enter the radio code which i have but the third digit is a 9 and i dont know how to enter a 9 as there is only buttons 1-6 on the radio so that is my question how to enter numbers higher than 6
any help would be much appreciated
Old Jul 21, 2011 | 03:45 AM
rw64's Avatar
use to first four numbers then press them ie if the first number is 8 then press it 8 times
Old Jul 21, 2011 | 05:44 AM
blingy's Avatar
hi sorry call me thick but your reply didnt make any sense the code is only 4 digits in lenght and the 3rd digit is a nine
Old Jul 21, 2011 | 07:00 AM
Up4Si's Avatar
blingy: it makes sense to me. If your third digit is a nine, then press the number three nine times. Number three becouse you are entering a digit of a 3rd field and nine times to rise it's value from one to nine.
Old Jul 21, 2011 | 09:40 AM
blingy's Avatar
Default entering the radio code
hi thanks that makes more sense now but it doesnt work when i press the third button all it does is enters number 3 in the third and the fourth then tells me codes worng and locks for 2 hours
i hope this makes sense the numbers dont rise
for instance if i press the 3 key more than once it just enters a 3 in each space.
Old Aug 12, 2011 | 11:30 AM
pacman069's Avatar
any luck blingy ??? i have same problem with an 8
krqadan
26
Jan 2, 2024 06:23 AM
wignut
Nov 1, 2021 10:07 AM
Rdecode
17
Apr 4, 2021 05:16 PM
pacman069
Nov 16, 2019 10:58 AM
cyrone
Mar 24, 2011 11:39 PM
