Faulty Speedo Help Auto 2.8 crd
Hi
I have a 2005 2.8 voyager Crd Auto.
My Speedo refuses to work, I have done the reset and there is no error codes. The cluster is calibrated as it should be. I have even replaced the cluster but to no avail.
im at a loss, there is no lights on the dash warning me of any issues. The gear box doesn't seem to have trouble shifting and there is no loss of power.
can any of you please help me shed any light on the problem?
hmm, that is odd. It could be the transmission control module it not sending out the speed message.
You'll need decent diagnostics to view the data from the TCM. Depending upon where you are the country I may be able to help you out.
Regards
Richard
Regards
Richard
unfortunately not, I'm in Cambridgeshire.
Is the dash showing a box around which gear you are in P,R,D etc? as that will prove that the dash is talking to the EATX (gearbox ecu). If the gearbox is changing gears at what seems to be the correct point then the input and output speed sensors must be working - which is what makes it a bit of an odd fault
Regards
Richard
Regards
Richard
