Faulty Speedo Help Auto 2.8 crd
Old Mar 12, 2014 | 09:37 AM
Terry Doran's Avatar
Sorry been away.
I've had the car ran through diagnostics, and it doesn't pick up a single fault?
The guy who did it said Because of the lack of fault codes it coul be a broken wire into the abs module. Estimated cost of finding wire £200-£500 :-0 does this sound right?
Old Mar 12, 2014 | 10:02 AM
Leedsman's Avatar
Assuming it's an 'analog' speedo like mine, try tapping the plexi with your knuckles while watching the pointer against the end-stop. (No need to be driving it). If the needle bounces ever so slightly from the end stop at least you know the mechanism isn't jammed.
Leedsman.
Old Mar 12, 2014 | 03:32 PM
tfb's Avatar
tfb
Originally Posted by Terry Doran
Sorry been away.
nope, a load of bollocks.
Speedo is driven by data message from (BCM) Body Control Module, which in turn is receives a data message from the EATX (gearbox module)
IF you can get it over to me (PE16) during the weekend, I can have a look. I don't charge and you'll get a decent cup of coffee too!
Regards
Richard
Old Mar 16, 2014 | 10:20 AM
Thanks Richard had a christening do and work this weekend so spare time was non existent. However on the way up to the christening today my engine warning light came on and my voyager wouldn't change gear! So I limped to the christening in what felt like first . After the do light was still on but it's changing gear again??
Old Mar 16, 2014 | 10:39 AM
  #15
Just done the key dance and got the following error codes.
po65.1
po530
Old Mar 16, 2014 | 05:19 PM
  #16
tfb's Avatar
tfb
That is the code for the B sensor reference voltage and it gives a reference 5V to among other things the A/C pressure sensor which is the other code. I'll look through the diagrams for you tomorrow and give you a bit more info.
Regards
Richard
Old Mar 16, 2014 | 06:21 PM
  #17
Leedsman's Avatar
One would assume you did the battery -ve disconnect for a few minutes to hard reset the micros right at the beginning?
Leedsman.
Old Mar 17, 2014 | 11:11 AM
  #18
tfb's Avatar
tfb
The ECU has two reference voltages for various sensor. The B reference is used for the A/C pressure and the boost/ air temp.
options for the failure are:
wiring fault dragging the 5V down
sensor dragging the 5V down
ECU not sending out 5V
or nothing actually wrong with it, but the ECU thinks it's faulty (have seen that with the A reference voltage)
somewhere i did have a schematic which showed which sensor used the A reference and which used the B - but I'll be buggered if i can find it!
Best way to proceed is to measure the B reference voltage at the ECU, if it's below 5V then disconnect the wire and measure again. If then it's still below 5V then it's the ECU and if it's back up then disconnect the sensors one at a time and then see if the voltage returns to 5V.
Pinouts can be found at the end of this document
http://oskin.ru/pub/chrysler-dodge/m...Powertrain.pdf
circuit diagram is 703027 and can be found here
http://1drv.ms/1c7pXkU
Regards
Richard
Evertb
17
Apr 21, 2022 04:00 PM
big-red-bus
Jun 12, 2011 07:50 AM
chrysler man
May 23, 2011 10:03 AM
Jun 16, 2006 08:21 PM
lineman 250
Jul 14, 2005 10:35 PM
