First electrical problem.. :-(
Old Jun 16, 2014 | 05:49 AM
  #21
Battery charger, 12 months per annum, never plug it in to the mains supply, more on that subject here.
Old Jun 16, 2014 | 06:46 AM
  #22
Originally Posted by Merlecollins
Ive done a multimeter test on it this morning:
I'm getting dead on 11.7 on the battery without the engine running.
I then jump started it and qickly done a one with the engine running before it cut out and was getting an erratic jump from approx. 6.1 to approx. 7.1
Sounds like your alternator's knackered.
Old Jun 16, 2014 | 05:15 PM
  #23
Merlecollins's Avatar
OK....
I bought a heavy duty charger this morning and have had the battery on charge since 11.30 this morning.
It's now 11.15pm and I've just disconnected the battery charger and tested the battery which gave a reading of 13.17 on the meter.
I then started the car, which it did first time, and it showed a reading of 11.91 to 11.94 with the engine running.
I then turned the interior blowers on and it reduced the reading down to 11.81 to 11.84 with the engine running.
Hopefully, it will start OK in the morning....
Old Jun 16, 2014 | 06:29 PM
  #24
Best of luck for the morning M8, a long slow charge is better than a quick one. With revs on at say 2000 that reading is low it should be closer to [13.8 to 14.2] 14 volts. So if it continues you may need to look at the voltage regulator on your alternator, or the alternator itself.
Old Jun 16, 2014 | 06:33 PM
  #25
Vmaxxer's Avatar
I am 99% sure the rectifier/regulator is/are broken.
I had the same with my motorbike and also with several older cars I owned.
Old Jun 17, 2014 | 02:16 AM
  #26
Thanks QinteQ and Vmaxxer
Is the regulator/rectifier that you tqalk about part of the alternator or a separate part altogether? Is there a definitive way to find out if that is at fault? Expensive job?
I'm guessing if it is that part that the battery will keep draining?
Old Jun 17, 2014 | 03:20 AM
  #27
rodger's Avatar
Hi
Its worth checking the alternator pulley before condemming the alternator, make sure the pulley is turning the rotor inside. These are OAD pulleys, they are not a solid pulley see this.
Veyance Technologies: Understanding Alternator Pulley Technology - YouTube
The "regulator" I think is part of the ECU engine management system, not integral to the alternator.
I had the same problem, flat battery and the gremlin dials movement and it was the alternator.
When you fix it, you might want to do the 33k Ohm mod to the temperature sensor that some of us have done. Basically it ups the float voltage from just under 14 V (for the Gel Spiral original battery) to just over 14 V (for a normal lead acid battery) I think its a "Leedsman" thread, I'll try and find it for you.
Hope this helps.
Rodger
Old Jun 17, 2014 | 01:25 PM
  #28
Originally Posted by rodger
Hi
Hope this helps.
Rodger
Thats brilliant, thanks Rodger.
My wife drove approx. 22 miles today and only just managed to get home before the car cut out again with a flat battery...
I spoke to the mechanic we use who unfortunately doesnt have the time until next Tuesday to look at the car, but he said it sounded very like an alternator failure...
I got a price at our local factors today for a new alternator and they quoted £320+VAT for a new Sovereign one
Might just wait till the garage have looked at it first in case it is the pulley or belt
Old Jun 17, 2014 | 01:34 PM
  #29
You can get new alternators for less than that, see Eurocarparts as an example, and you could probably get a good used one for a lot less from an on-line breakers.
Attached Thumbnails First electrical problem.. :-(-alternator.jpg
Old Jun 17, 2014 | 01:50 PM
  #30
I just spoke to a friend of mine in the trade and he seems to think along the lines of Rodger, in that, I should rule out other simpler possibilities first.
He has suggested that a diagnostic machine may throw up a fault in the ECU caused after jump starting the car...
I may attempt to get a diagnostic ran on the car as a starting point.
