Front blower motor inop
Old Nov 21, 2013 | 08:48 PM
rhino's Avatar
Default Front blower motor inop
I have a 2002 T&C with ATC. Doesn't work on any speeds. I am out of ideas. Replaced the following: resistor, fan motor, and tried a different control unit. I have power at the relay and fuses and tried different relays as well. Is there a wiring diagram anywhere? Bad ground? Anybody have any ideas?
Old Nov 22, 2013 | 02:05 AM
do u have power and ground at teh motor when its on the main connector?
Old Nov 22, 2013 | 03:41 AM
Raptor 07's Avatar
Diagram? Send me a private message and include an email address.
Old Nov 22, 2013 | 09:13 AM
rhino's Avatar
Yes there is power.
Old Nov 22, 2013 | 02:02 PM
Raptor 07's Avatar
Sent the diagram. If you have 12vdc power and a good ground at the blower motor connector that only leaves the motor as the culprit.
Old Nov 23, 2013 | 04:04 PM
rhino's Avatar
ok I have a diagram thanx to Raptor07. Heres what I have noticed. With the key on I have power to 2 wires going to the blower motor resistor and there is power going to both wires to the blower motor from the resistor. But if I disconnect the the blower from the resistor there is only power coming from one of the two points of contact. I have also bench tested the blower motor and it works.
Old Nov 23, 2013 | 05:38 PM
rhino's Avatar
Also I noticed I lose voltage as i increase the fan speed. Down to 2.7 v
Old Nov 23, 2013 | 11:59 PM
ok dark blue wire has 12v when key on?
Dark blue let blue wire will have different voltage based off the speed of the know
And u have a good ground on the black and orange wire right?
Old Nov 24, 2013 | 11:05 AM
rhino's Avatar
ok I believe I have a good ground. Now there is 2 wires on the blower motor. Should there be power to both wires or is one the ground? I bench tested the motor and it didn't matter where I put the power or ground it still worked.
Old Nov 24, 2013 | 05:11 PM
the resistor provides the power and the ground so if U have power on both side the resistor is not providing the ground. Where did u get the parts from new or used?
