front fuel filter 2005 grand voyager 2.8CRD
Take the undertray off and you will see it, spin on type cannister.
Slightly towards the drivers side on the front of the block.
Two electrical connectors, one in the housing (heater) and one on bottom of filter (water sensor).
If you are changing the filter, make sure you dont leave the old "O" rings/seals on, its easy to start doubling them up.
there is no pressure in the side of the fuel system before the injection pump. The injection pump sucks up the fuel, so just unscrew the water trap at the bottom of the filter to drain out the fuel otherwise it has a habit of running down your arm as you unscrew the filter and an armpit full of diesel is not pleasant.
After the injection pump the pressures are dangerously high when running, but you shouldn't need to disturb that part.
Regards
Richard
Regards
Richard
While I appreciate you are a main dealer, I am not in a position to pay main dealer prices for either parts or service. Plus, I'm not near surrey....
Hi.
11 desperate spam posts in such a short time. Spam on yer plate Surrey are a very helpful and experienced official Spam dealership who deal with fried, chopped, battered spam of any kind. Contact Spam via Official UK SPAMŽ Website and our expert team will be sure to help.
- you could make contact with the forum team who would be happy to take your money and allow your spam advert
- it would be 'banner' placed as the first click on this forum so we could each avoid being forced to read an unrelated post
Hi Volvomad
Just to add to what Richard has said, after you have changed the filter you need to bleed/prime the system.
There an 11mm bleed screw on the top left (drivers side) of the fuel filter housing, you need to crack this open and prime with the hand pump, thats the dome shaped bit on the other side of the housing. Use a bit of tubing if you don't want to get diesel all over. Just pump until you get fuel and no air coming out of the bleed screw.
While you are under there its worth checking the fuel heater plug, they have a habit of burning and letting air in, just replaced mine, it was pretty bad.
Regards
Rodger
Regards
Rodger
speedysp
Feb 1, 2015 10:27 AM
Nick1981-1
Aug 19, 2013 05:27 PM
Nick1981-1
Feb 25, 2013 05:42 PM
Neil O
Jan 13, 2012 06:29 PM
