Gauge ?
Old Jul 23, 2011 | 12:48 AM
Joe C's Avatar
Default Gauge ?
First post, I miss my gauges, is there any way to install an oil pressure gauge & volt meter in my 2010 T & C so it looks like factory?
Old Jul 24, 2011 | 03:30 PM
TNtech's Avatar
It won't look factory. There are many aftermarket guage sets out therem but you'll have to do some wiring work to make it happen.
Old Jul 26, 2011 | 09:04 AM
oldgrumpy's Avatar
I put a ScanGaugeII into my 2009 T&C. Easy install, no wiring just plug into the OBD port to left of steering column at base of dash. Volt read out but no Oil Pressure, Temp. or Trans. Temp unfortunately. Maybe someone else has figured out how to read the OBDII codes for that information.
Old Jul 29, 2011 | 08:53 AM
ettienne's Avatar
No oil pressure reading is available on OBD, you need to install and aftermarket gauge for that.
Old Jul 30, 2011 | 08:56 AM
TNtech's Avatar
Actually there is on CAN BUS vehicles. Before that no, you could not read anything. The Minivans not until 2012 models I think.
Old Jul 30, 2011 | 11:25 AM
oldgrumpy's Avatar
Thanks for that info. TNtech. Perhaps then, if the codes are 'transferable', either ScanGauge or someone more capable than I will be able to program those codes into an existing SGII for pre 2012 vehicles that use the CAN BUS.
Old Aug 1, 2011 | 02:45 PM
ettienne's Avatar
Oil pressure readings are simply not available on the older vehicles, nothing can be done to make SGII read it.
Old Aug 1, 2011 | 08:40 PM
oldgrumpy's Avatar
It would be great to have it all, but if I could see the oil and trans. temp. that would be terrific.
PacificaBEW
Aug 9, 2011 11:41 AM
gottalebaron86
Aug 26, 2008 10:08 PM
crashputer
Oct 1, 2006 09:38 AM
94_LHS
Aug 1, 2006 02:24 AM
Sofargone
Aug 16, 2005 09:14 PM
