Gearshift cables Voyager 2.5 CRD RGYN37 05 CRD 105kl
Old Aug 24, 2018 | 12:35 PM
Dea-ita's Avatar
Default Gearshift cables Voyager 2.5 CRD RGYN37 05 CRD 105kl
I have a problem with the rubber/plastic spacer at the end of the gearshift cables
they are breaking slowly slowly...
same problems happened on previuos Voyager (same 2 parts were also broken on the other side of the cables locared below the main gear lever i but i was lucky to find a second hand broken cable where to take out only the small parts.
Do you have any suggestion to avoid changing the whole cables?
Thanks and greetings from Italy
At the end of the cables look at the small parts indicated by the 2 red arrows
Old Sep 5, 2018 | 07:46 AM
Dea-ita's Avatar
It seems I'm the only one to experience this kind of problem...
I'll let you if there is a solution rather than replace the cables...
Old Dec 2, 2018 | 07:22 PM
Nikkiandstephen Cadden's Avatar
Mine is doing exact same thing. Noticed it yesterday when I was inspecting the master cylinder. Experiencing a brake issue I'm trying to fix at the moment.
Old Dec 5, 2018 | 04:21 PM
Dea-ita's Avatar
Mechanic in Rome, fixed it.
I can show picture which is almost self explanatory but I don't know details.
I can confirm that it is working well.
Mathnik
Mar 20, 2017 11:52 AM
andyeastsussex
Apr 27, 2015 01:04 PM
dannylivo
Sep 24, 2011 03:51 AM
Grizzly12
Feb 16, 2011 02:23 AM
neily68
Jul 16, 2010 07:34 AM
