Grand Voyager 1998 2,5TD. Electronic and BCM troubles. Do not starts
Old Feb 21, 2014 | 04:24 PM
Opera on Win8.2, opens them full format. If not put the *.svg file in here for a pdf format output
Old Feb 21, 2014 | 04:27 PM
Duplicate post
Old Mar 6, 2014 | 07:34 AM
nectis's Avatar
Question Hopefully I've found the reason of problem
Dears,
hopefully I've found the reason of non working of BCM and JunctionBox.
After hours of CCD Bus testings and thinking about the reason of the issue, I've found that is looks like Key sty in the Off position:
1) Overhead console works (without love data from BCM), test shows PASS (CCD Bus works)
2) No ANY ground shortcuts, all wires and modules are connected well
3) Everything else works without problem as should work in switched OFF Key position
4) Odometer is Off
5) Before the Ignition Switch in OFF position have +12,7 Volts
6) Before the Ignition Switch in ON position have +11,8 Volts
I think there is + Battery Cable is disconnected or shorted to ground somewhere.
Have anyone some ideas to where to look for?
Old Mar 6, 2014 | 05:42 PM
nectis's Avatar
Comment:
To JunctionBox comes 4 +12V wires - one direct and three from ignition switch.
The voltage from direct and two (ST-RUN, RUN-ACC) wires is stable, same as at Battery +12,7,
but on the ST-RUN-OFF wire at switching the key to Off and Run position is decreases to +11,8.
Where to look for?
skylinefeb75
Mar 19, 2013 06:41 PM
suz.co
Dec 21, 2011 06:04 AM
kasandera
Aug 15, 2011 06:47 PM
Ephata
Jan 12, 2011 11:43 AM
tmerila
Aug 28, 2009 02:45 AM
