Grand Voyager won't start anymore
Old May 26, 2016 | 10:44 AM
Pietje Bell's Avatar
It was the starting motor, but I will go to the garage to check the battery. Thanks everyone for you help.
Eddy
Old May 26, 2016 | 10:59 AM
Pleased that you got it sorted Eddy. Thanks for the feedback.
Old Jun 3, 2016 | 08:40 AM
Hi back again. After weeks without any problem, the problems started this afternoon, when the brake lights started to burn without my handbrake on and the radio didn't work. So I decided to go home, stopped the engine and tried to start again, only clicking and dashboard lights where out with the contact on. After that a lot of noise comming from the new starting motor (with the contact OFF), because it didn't stop I took of the - cable of the battery, with that I burned my hand,,because the - cable and the + cable where very hot. Is this problem coming from a bad battery. or an other problem?
Old Jun 3, 2016 | 05:12 PM
I still think its bad battery or resistance in the + cable. Eliminate the battery is easy and cost free if you borrow a known good. Cable resistance - do this after eliminating battery, if your battery is in the boot on a long cable you are going to have high[er] loss & high resistance to 'high current devices' like starters unless its an oversized cable and good or better connection quality.
p0z3r
Mar 25, 2017 10:04 PM
Geoff
Aug 17, 2013 04:32 PM
laura
Apr 11, 2010 08:48 PM
ruki
27
Jul 3, 2009 02:59 AM
May 14, 2008 08:53 PM
