handbrake
Yes you can.
Do you have a european style floor mounted lever or a pedal type?
TBH poor handbrake is often due to the self adjusters not working properly on the rear brakes, wip the drums off & check that the shoe to drum clearance isn't excessive first.
I think the cable adjustment is under the left side of the car if memory serves.
Also, if its a lever, the lever is supposed to come a long way up [so I'm told]. Basicly there's a lot of free travel. There's a double pawl & quadrant under the center console. You'll see how it works if you watch it operate as you lift the lever. I've modified mine to take up the free play so when i pull the lever the brake starts to operate after 3-4 clicks, It'll hold the car & caravan on a steep hill now!
Yeah the bellcrank is a real stupid arrangement that without the self modification that gareth mentions facilitates NO compensation for strecthing of the actual cable. I wonder how much they paid for some bright spark to come up with that dumb idea.
More details on my 'modification'. All I did was tape a 10 pence coin [about the size of a quater] to the floor to stop the mechanisum reaching the point where the pall dropped out of the quadrant. I then used a lever to pull up the slack in the cable until it was just starting to tighten but not apply the brakes.
harrysaimbhi
Mar 29, 2011 04:24 PM
daddy day care
Feb 25, 2011 12:25 PM
milesy_boy
Oct 8, 2009 05:54 PM
