Heater issue (headliner vents)
Old Jan 3, 2013 | 10:18 PM
dedwardk's Avatar
Default Heater issue (headliner vents)
I dont get any heat out of the vents on top. When I turn the switch nothing happens at all.
Where do I begin troubleshooting the upper vents ?
front and rear are ok
2000 T&C Limited
Old Jan 4, 2013 | 02:35 PM
Raptor 07's Avatar
Is heat or at least blowing air coming out of a vent near the floor at the middle passenger side seat?
Old Jan 4, 2013 | 03:34 PM
dedwardk's Avatar
are you referring to under the second row seat ? or a vent under the main passenger seat blowing back ?
and does it matter what front setting you have turned on ?
Old Jan 4, 2013 | 03:56 PM
Raptor 07's Avatar
To the right and just behind the middle passenger seat low near the floor.
Old Jan 7, 2013 | 08:45 PM
robert19701989's Avatar
If front main dial is on floor/window/defrost, the heat will only come out at feet by outlet on passenger side sliding door. If main dial is on dash vents, air comes out headliner vents. At least this is how mine works. If you want heat from headliners, put main dial on dash vents and turn thermostat to hot/red, and rear fan on high to see what happens. Rob
Old Jan 8, 2013 | 09:56 AM
dedwardk's Avatar
ok so there is no vents under the seat... only on the pillar where sliding door opens too...
also my settings were correct so thats no issue ..
Robert do you have a switch on top headliner ?? right behind drivers seat ceiling ?
mine doesnt do anything when turned on ... wonder if it has a tegulator like front blower switch does .. know when only high position works you need to change that little doo drop thingy under hood on firewall
wdwrker1
Feb 4, 2019 10:41 PM
Jake103
Jul 1, 2010 02:53 PM
mkoppler12
Jan 4, 2010 06:01 AM
RobNordic
Sep 14, 2009 07:40 PM
gmullen
Apr 25, 2008 08:35 PM
