heater loud knocking and noise behind driver side front panel
Old Nov 13, 2023 | 02:30 PM
AZbird's Avatar
Default heater loud knocking and noise behind driver side front panel
I've got a great running 08 T&C with a really clean interior. We really like our van. But it does have some issues. Currently, I'd like to fix the issue with the crazy knocking and buzzing noise it makes when the heater is on, or sometimes even off, and sometimes even when the van is completely shut off - it just keeps on banging and whirring. I'm going to dig into it real soon but thought I'd throw this out there in case anyone's dealt with it.
Old Nov 14, 2023 | 09:34 PM
likely a blend air motor or modode door motor look under the dash driver and pass side when you hear it you can feel the motors making noise
Old Nov 16, 2023 | 10:00 AM
AZbird's Avatar
Thank you CT. I think I found a possible culprit; the accuator. I pulled it and opened it up, and some of the gear teeth were broken off.
Old Nov 18, 2023 | 07:41 AM
AZbird's Avatar
Default heater loud banging and whirring cured - actuator
UPDATE: I installed the actuator on the driver's side (I assume there is one on the passenger side, too). The actuator adjusts the vent openings to get the right temperature mix to the cabin. A "simple" fix and the previous owner had actually left one with the van when we bought it. I say a "simple" fix because it's two screws out, remove and replace, and two screws in. But my back is still aching from twisting and turning to get under the dash to reach up to where the actuator sits and get a little socket with a little star bit on the screws. ADVICE: If you have to do this, be sure to have a magnetic reacher because the screws might drop down into the vent area, like mine did, but I got them out with the magnet. Also, if you don't have a magnet socket wrench, put a tissue inside your socket to hold your star bit - you don't want to get all twisted up under there and then lose the bit.
twodoctors
26
Mar 17, 2015 12:47 PM
steviemac74
Feb 28, 2011 06:33 AM
dhhbomb
Feb 11, 2009 01:11 PM
bargdill
Dec 4, 2007 01:19 PM
yf02055
Jan 9, 2007 05:59 PM
