Heater Problem
Old Dec 27, 2008 | 06:02 AM
Trevor Barnard's Avatar
Default Heater Problem
Hi Guys, I'm new here but pleased to have found the forum! I have a 2002 Grand Voyager 2.5CRD. Great vehicle and I'd definitely have another.
I'm about to change the anti-roll bar bushes to eradicate that annoying knocking! I'm also sorting out the cold starting problem - relay or glow plugs. I need some help with another problem. I'm sure it's been covered but a search didn't find anything.
The engine refuses to warm up when the weather is cold. The heater barely gets warm. It's fine when the weather is milder. Any ideas?
Thanks and a Happy New Year.
Trevor
Old Dec 27, 2008 | 12:13 PM
Merlin's Avatar
Default RE: Heater Problem
Have you checked the water level? And does the cabin heater work when you first start up?
Old Dec 29, 2008 | 06:10 AM
Water level is fine. I checked that first as on previous vehicles that I have owned with similiar problems it has turned out to be an airlock. A lot of modern motors now have a cooling system bleed valve.
In mild weather it is fine but when it's cold - and that's when I need the heater - it refuses to get warm enough to make any difference. The temperature gauge stays at the bottom end. I suspect thermostat but I've no idea where it is hidden!
Trevor
LynnieS
Sep 13, 2013 01:04 AM
skywalker
Jan 22, 2011 08:19 AM
gryphin2004
Oct 28, 2009 10:06 PM
madman
Jun 20, 2008 08:35 AM
timmyv
Jan 28, 2007 08:03 PM
