Highbeams are no working on my 2001 Town & Country.
Old Oct 13, 2008 | 08:39 PM
3.3lxbluevan's Avatar
Default Highbeams are no working on my 2001 Town & Country.
I have replaced my headlights bulbs thinking that was going to solve my problems but It did not. I have checked the foglight fuse and the relay and they all are good but I am still having one side that lights up and the otherside that Is not lightning up untill I cut off the highbeams. Is there anythingthat I am missing.
Old Oct 14, 2008 | 11:44 PM
Default RE: Highbeams are no working on my 2001 Town & Country.
possible front controller or IPM
Old Oct 16, 2008 | 06:15 PM
What is a front controller and what does the IPM stand for and what does It really do?
Old Oct 17, 2008 | 01:24 AM
front controller is a small computer that controls many of the lights and several other things to many to list.
The IPM is Intelligent Power module or basically fuse block that the front controller attaches to.
Old Aug 20, 2014 | 07:15 AM
lewlock's Avatar
so do these need to be replaced or can the front controller be reprogrammed?
Old Aug 20, 2014 | 02:55 PM
Here's a clue for you that I found and someone else mentioned. My can had no dipped beam on nearside and after investigation on another fault I found a bypass wire between headlight and front controller was disconnected. Fitted this wire and headlight now ok, hence broken wire in loom. So from underneath car left/nearside UK, check wiring loom as I found the harness was rubbing through on the wing plastic mud deflector.
Here's a picture of the TPM tipped up and the Controller is the silver box on front of it. Take note that connectors on underside of IPM cause problems if the connections need cleaned. Its a known fault on Voyagers.
Attached Thumbnails  Highbeams are no working on my 2001 Town & Country.-battery-4.jpg
3.3lxbluevan
Mar 18, 2009 07:55 PM
joshuakline
May 5, 2008 05:43 PM
joshuakline
Apr 30, 2008 10:59 PM
vlsgmc
Apr 4, 2008 09:26 PM
bradybun
Oct 13, 2005 07:18 PM
