Hissing noise from vents when heater on.
Old Mar 17, 2013 | 11:02 AM
wdwrker1's Avatar
Default Hissing noise from vents when heater on.
I have an intermittent hissing sound (like steam from a radiator) whenever fan is on. Will last a few minutes, then go away for a few minutes. Only using heater this time of year, so it's not AC. Besides, had entire AC system replaced last year. Turn fan off, and hissing goes away, never had a bad fan hiss before, if that's to blame.
Old Mar 17, 2013 | 10:52 PM
Do u have it on defrost when it makes that sound?
Old Mar 18, 2013 | 12:19 PM
wdwrker1's Avatar
Yes, it's set on split, defrost and vent. So I must be hearing defrost cycling. Is that hissing normal then on a 2006 Touring w/ (new) rear AC?
Old Mar 18, 2013 | 02:27 PM
that hissing sound is then the freon moving through w the defrost on the ac compressor comes for for a short time to remove moisture from the incoming air.
If it gets worse then u have low freon and a leak some where.
Old Mar 18, 2013 | 06:23 PM
wdwrker1's Avatar
Thanks Kevin, hope it's not a leak & she blows cold for our B'more summer!
Old Mar 18, 2013 | 08:37 PM
the hissing is the freon passing through the evap core in the dash.
Old Feb 4, 2019 | 10:41 PM
B Johnson411's Avatar
Smile 08 Saturn Outlook
Can this also be the issue on my truck, getting same noise, same location and shortly after I turn on heat/defrost. It does stop especially after I have been driving it and it gets warm. I thought it may have something to do with moisture, I was just guessing. Thanks!
StarrySeedling
Sep 16, 2017 12:08 AM
atravis4
May 23, 2012 01:54 PM
Layce
Oct 18, 2010 09:23 AM
prsolar2001
Dec 5, 2009 04:29 PM
gmullen
Apr 25, 2008 08:35 PM
