Hot Blower Motor Resistor
Old Feb 19, 2013 | 05:27 AM
jsb1964's Avatar
Default Hot Blower Motor Resistor
Good Morning All, The front blower motor resistor on my 2001 T&C stopped working. After researching I replaced the blower motor resistor which had overheated and part of the plastic had melted at one of the connections. After replacement, the fan worked fine on all speeds but I soon noticed a burning smell. The resistor is hot to the touch. Could this be a fan motor issue? Thanks!!
Old Feb 19, 2013 | 03:39 PM
Default Hot Blower Motor Resistor.
I'd put this down to heater fan needing a bit lubrication at its bearings. Brushes maybe. How do you get to it. Dash out no doubt. Anybody know !
Goggs.
Old Feb 24, 2013 | 03:41 PM
Default Hot Resistor
Hi, any result came of this regarding checking motor works with direct feed or what...
Goggs..
Old Apr 2, 2013 | 10:20 AM
epicazoi's Avatar
Late reply,
I was experiencing the same issue with my 2001 T&C, I replaced the resistor and the metal part was burning up hot! so I discovered that by moving the blower with a stick or even by hand would make the blower work again, meaning that the blower will get stuck and you are right Goggs bearing needs lubrication or else you will be spending money on another blower resistor.
Old Apr 2, 2013 | 01:57 PM
replace the blower motor itself u cant lube up a sealed electrical motor.
Vanman
15
Jul 17, 2009 06:17 PM
netdealz
Nov 26, 2008 06:09 PM
mrotis
Jan 14, 2008 01:27 PM
bmfay
Apr 9, 2007 08:37 PM
bmfay
Apr 2, 2007 09:49 PM
