Instrument Panel
Old Dec 18, 2016 | 03:05 PM
DarkBMW's Avatar
Question Instrument Panel
Hi all!
How to remove the entire front Instrument Panel (5)
I need to lay the wiring from the right-hand A-pillar to the radio (1)
Many thanks!
Old Dec 18, 2016 | 07:35 PM
Get a set of plastic trim tools. They are inexpensive and worth their weight in gold for prying off parts of the dash without scarring them up. Use an appropriate trim tool to pry off the bezel around the radio (12). Then you will see how to remove the radio. Route the wire behind the glove box to the radio. Remove the glove box if necessary. You don't want to be removing the entire dash panel unless absolutely necessary. You should be able to run your wire without doing so.
Old Dec 19, 2016 | 01:17 AM
DarkBMW's Avatar
thanks for the advice. At wiring much more additional connectors, I want them to also connect to their seats. Me said it is necessary to remove the entire panel.
71grande
May 23, 2010 08:55 PM
Josho
Nov 25, 2008 01:24 AM
TheCoutures
Sep 17, 2008 09:04 AM
anabel99
May 26, 2008 09:13 PM
sistegraf
Dec 21, 2007 05:23 PM
