interior light problem ( help)
Old Feb 14, 2012 | 02:19 PM
NicKeiRacing's Avatar
Question interior light problem ( help)
i have a t reg 3.3 grand voyager and having a problem with the interior lights.
they can be turned on and off when pressing the lights themselves,
but wont come on when a door is opened, the door ajar light comes on the dash but no interior lights,
the fuse under the bonnet is fine and have checked the relay inside the car that i was told could be at fault, (bottom row, far right)
hope someone can help
Old Feb 14, 2012 | 06:03 PM
Raptor 07's Avatar
The BCM contains the driver circuits for interior lighting. Try pulling the IOD fuse in the PDC for 2-3 minutes to reset it.
Old Feb 14, 2012 | 07:27 PM
Thanks.
Can you confirm where the iod fuse is
thanks
Old Feb 15, 2012 | 01:18 AM
Raptor 07's Avatar
In your fuse box under the hood. If you can't find it just disconnect the negative battery cable for 2-3 minutes.
Old Feb 15, 2012 | 06:57 AM
Originally Posted by NicKeiRacing
Thanks.
thanks
look :
20A IOD - bottom LHS of the pic, note all the fuse & relay locations are inside the lid of the fusebox
Old Feb 15, 2012 | 12:45 PM
thanks, will have a look and try that tomorrow as i leave the car at work while im respraying it.
will let you know how i get on, if it works or not.
thanks again
Old Feb 15, 2012 | 01:39 PM
- I've just realised that pic I sent you was from a 2.8 CRD not a 3.3, sorry my friend
Old Feb 15, 2012 | 02:05 PM
Thats ok.
The fuse on mine was a 10amp fuse
ive took it out for about 5 mins and still no interior lights when you open a door
Old Feb 16, 2012 | 01:36 PM
Raptor 07's Avatar
May not apply but if I rotate my lights dimmer control on my 96 all the way down past the detent my interior lights won't come on when I open a door. It activates what Chrysler calls the Interior Lights Defeat Feature. Check you manual.
Old Feb 17, 2012 | 01:04 PM
ive tried moving the dimmer swith around and nothing
previous owner has put a extra earth wire from the switch which i have tried disconecting and then mess's all the lights up,
i tried another switch but was from a model with no fog lights just to try and still nothing.
is there a quick fix of some kind to rewire the lot???
