Interior lights won't come on when drivers door opened
Old Sep 21, 2011 | 09:00 PM
dakotajw's Avatar
Default Interior lights won't come on when drivers door opened
New member here, have been lurking about for a while and found some great info. I have a '99 Ply. Grand Vovager and the interior lights won't come on when I open the drivers door. Does the door ajar switch control that function through the bcm? The switch appears to be good as the 'door ajar' light will come on when the door is opened and also the alarm/chime will sound if I open the door with the keys still in the ignition. The lights will come on when any other door is opened. Is this something that can be rectified without replacing the bcm or is there something else in the system that I'm missing. I've had no luck using the search feature, the only results I came up with had gone unanswered. Thanks in advance for any help you can give me.-Jim.
Old Sep 22, 2011 | 04:05 AM
Robertehv's Avatar
Try to toggle the interior light switch left of the steering wheel. If in top position lights will be off.
Old Sep 22, 2011 | 05:23 PM
dakotajw's Avatar
Thanks for the wake-up, Robertehv, I must've had a brain freeze. Didn't think to check that. It solved my problem.
Old Sep 23, 2011 | 05:21 AM
Robertehv's Avatar
You're welcome.
Ann Garcia
May 19, 2015 10:17 AM
aerospac3
Jul 15, 2012 10:55 AM
tdavetice
Jul 25, 2010 10:38 AM
SportbikeRiderXX
Aug 18, 2008 07:56 AM
bourquepa
Dec 5, 2005 10:32 AM
