Issues after oil cooler replacement
Old Jan 1, 2020 | 10:50 AM
bamdoo's Avatar
Default Issues after oil cooler replacement
HI,
I have a 2014 Town and Country Touring-L with 104,000 miles on it. I noticed the van was leaking oil and could see it pooling around the oil filter housing. This led me to change out the oil cooler yesterday (I had to remove the throttle body in order to do so). While I had the car apart I also changed out the spark plugs and pcv valve. Now the van is running like garbage and giving me codes P0123, P0222, and P0571 in addition to the red blinking lightning bolt on the dashboard. The van didn't have any codes prior to yesterday. Any advice on getting the van running smoothly again would be greatly appreciated. Thanks in advance.
Old Jan 1, 2020 | 11:18 AM
Im guessing a 3.6? take a look at your throttle body connection.
Old Jan 1, 2020 | 01:21 PM
bamdoo's Avatar
Thanks, that was it. I didn't reconnect the wire to the throttle body.
Old Jan 1, 2020 | 07:22 PM
does the trick every time =)
BRay09
Mar 11, 2014 01:00 PM
vladio
Apr 5, 2012 09:35 AM
b_ron007
9
Dec 21, 2010 04:44 PM
aftab
Sep 2, 2010 03:14 PM
bbyers
Feb 21, 2010 09:29 AM
