Lambda probe sensor location
Old Dec 1, 2020 | 09:19 PM
tazmaniac_37752's Avatar
Originally Posted by ggoose
What is the part number that AutoZone noted? O2 sensors are ignored when first starting the motor, called open loop, so any miss or long cranking are not due to an O2 sensor.
A long crank time could be a fuel pump. You will need to check the fuel pressure at the fuel rail when starting; needs to be 45+ psi if I recall. Could have a dirty fuel injector, suggest adding some Techron to the fuel tank next fill up.
When was the last tuneup? The 3.3l is plugs, wires and a 6 terminal coil pack (that can go bad occasionally) if I recall. Could be corrosion on the coil pack terminals.
Thanks for your help and ideas. I will check the fuel pressure. I don't remember what the part number was but it did say that it was the same as a 02 sensor but there at that block in the AC lines sounds about right.
As for the " missing " problem. I have had trouble out of the wiring harness that goes to the fuel injectors on the front bank. I wound up completely rewireing one of then and patched the wires on a couple of he others.
Old Dec 1, 2020 | 09:22 PM
that looks like the connector that goes to the H block for the AC system it will go back to where the ac lines go into a silver block.
Im guessing your correct for where it goes. Judging by the wire length.
cuathetop
Sep 13, 2018 07:05 PM
Tobias Claren
Jul 15, 2018 07:50 AM
xlovesong
Dec 9, 2012 10:34 PM
brieanna82
Oct 7, 2010 07:52 PM
RayDog26
Dec 17, 2007 09:19 PM
