leaking coolant from passenger side front
Old Sep 25, 2011 | 01:21 AM
SP10025's Avatar
Default leaking coolant from passenger side front
ive noticed it a week ago. ive also notice its dripping down from were the belts spin on the passenger side of the engine i can see the drip but have no idea were its coming from it doesnt seam to be from the radiator hose on passenger side its coming from higher up. in side engine. can any one help
Old Sep 25, 2011 | 11:00 AM
TNtech's Avatar
Year model and engine size? Mileage can be a help too.
Old Dec 28, 2011 | 04:49 PM
Painplaya8's Avatar
Hello my name is steve and i am haveing the same issue I have a 2003 town and country 3.6 with about 118k on it please help me f you have any knowledge that may help me
Old Dec 28, 2011 | 10:31 PM
Any place on the engine that has coolant going through it can leak Get it pressure tested to see where the leak is coming from.
Old Dec 29, 2011 | 09:42 AM
jkersh1's Avatar
Just an idea. Is it engine coolant or windshield washer fluid? I have a '97 Caravan, and an '05 T&C and the reservoir for windshield fluid is stuffed up in the right front fender / engine compartment. I've had leaks due to a 1> cracked container and 2> loose hose to rear sprayer. The container on the '97 is really buried and very difficult to see what's happening. You can see the bottle on the '08 from underneath.
Old Dec 29, 2011 | 07:40 PM
MoparAiken's Avatar
Have 2006 with 90K miles. Coolant was leaking down the lower radiator hose. Triangle Dodge leak tested and replaced the water pump.
Old Jul 27, 2018 | 10:25 AM
Lunamariom's Avatar
Default Leak
Hopefully I can get an answer... not sure if it's water or coolant leak, but it only leaks we hen I put the car in gear, not when parked, seems to be from the back of the engine... any idea what it might be?? 2006 and 2007 Pacificas 3.5 and 3.8 both have same problem
Old Jul 27, 2018 | 02:31 PM
in gear not in gear would have nothing to d with a coolant leak. Did u feel what fluid what does it look like cold hot ?
aaden5823
Apr 27, 2019 10:17 PM
AdamLag
Nov 3, 2017 10:59 PM
mraskin
Mar 25, 2015 03:46 PM
Ibrld2
Apr 26, 2012 10:50 AM
teddysmith1952
Dec 16, 2011 08:31 PM
