Like a bucket of bricks......
Old Aug 24, 2013 | 06:40 AM
Nicko's Avatar
Default Like a bucket of bricks......
Ok after my reverse light stopped working I got my local auto electrician to bypass the bcm, this fixed what would have been an expensive problem!
However since this fix, changing gear has been like stirring a basket of bricks...
The auto electrician says it couldn't have been home and he went no were near the obvious culprit areas, but this all seems to be to much of a coincidence.
Any thoughts?
Old Aug 24, 2013 | 02:19 PM
Raptor 07's Avatar
Do you have a museum piece or something newer?
Old Aug 24, 2013 | 05:17 PM
Nicko's Avatar
Sorry forgot!
2.5 td 2002 voyager
Just read my own post "couldn't of been home" don't you just love it when your ipad wants to finish your sentences for you!
"Couldn't of been him"
Old Aug 24, 2013 | 05:35 PM
Leedsman's Avatar
Did you mean "couldn't have been him"?
Leedsman.
Old Aug 25, 2013 | 03:36 AM
Raptor 07's Avatar
If this shift problem started right after his "fix" then it sure points towards him. Did he mess with the Transmission Range Sensor (TRS) circuit in the transmission? That's what turns on the reverse lights. That will screw up shifting for sure. I'm assuming you have the 4 speed 41TE tranny.
Old Aug 30, 2013 | 03:09 AM
Nicko's Avatar
No Mate, mines a 5 speed manual...
Old Aug 30, 2013 | 12:47 PM
Raptor 07's Avatar
Ugh! Euro models do have their differences.
Old Aug 31, 2013 | 01:40 AM
tfb's Avatar
tfb
Being a manual I cant think of anything electronic that can interfere with changing gear.
Can you be a bit more descriptive? is is hard to get into gear, noisy etc?.
Check if a bit of carpet or trim is not fouling the clutch pedal as the BCM is down in that area. Other than that it's to check the mechanical linkage from the lever to the box.
Regards
Richard
STilt66
Nov 18, 2011 09:11 AM
3littlecampers
Jun 19, 2008 11:55 PM
3littlecampers
Jun 19, 2008 02:57 PM
mzsparky
Nov 1, 2005 11:22 AM
JXI101
Jul 17, 2005 02:36 AM
