Minor coolant loss/intermittent coolant smell inside car
Old Nov 19, 2015 | 05:38 PM
JaxJim's Avatar
Default Minor coolant loss/intermittent coolant smell inside car
2002 t&c 3.8. New radiator and cap and t-stat. Doesn't overheat and I don't see any leaks but now and then I get a coolant smell inside car (up to temp and heat and a/c off) and windows fog up slightly. Coolant loss is about 2 cups over a 2 week period. Oil shows no sign of water. No sign of leakage on water pump. Does this sound familiar to anyone? Thanks for any help!!
Old Nov 19, 2015 | 09:59 PM
heater core leaking
Old Nov 21, 2015 | 05:19 AM
I don't know if it works on heater cores but I have had 100% success in using Radweld or similar on engine, radiator and pipework leaks. Might be a quick cure or temporary sollution at this time of year.
Old Nov 21, 2015 | 11:29 AM
JaxJim's Avatar
I will definitely look into that. If it is the heater core, from what I hear and see, it is a bear to get out!
Old Nov 21, 2015 | 11:32 AM
JaxJim's Avatar
heater core leaking
I don't suppose there is a way to test that first?
Old Nov 22, 2015 | 10:18 AM
pressure test it look for leaks
Old Nov 22, 2015 | 12:16 PM
Best to pressure test it when coolant is cold because when coolant heats up the metal expands and stops the leak..was a problem with big hulking mainline diesel engine cooler groups back then when the coolant ran out when engine shut down for even a day.
Racer
Dec 1, 2013 01:08 PM
Evertb
Jan 17, 2013 01:12 PM
SSJ
Apr 12, 2011 04:36 AM
musicfreak2195
Mar 29, 2009 08:55 AM
Jan 1, 2005 05:41 PM
