My brakes are not very good...
Old May 28, 2011 | 07:30 AM
dj-vega's Avatar
Default My brakes are not very good...
Hey guys.
i am new member here. young guy from norway.
I have a Crysler Grand Voyager... 3,3l, automatic trans, no a/c...
We bought it for a couple days ago,
The car is in pretty good condition, not mint but ok.
To problems so far.
Cooling fan is not working (car temp is ok on the temp gauge)
abs light does not engage when we start the engine.
Any help?
Thank you guys so much.
Old May 28, 2011 | 03:00 PM
get the spec sheep and see if the van even came with abs to start with.
how do u know the fans are not working?
Old May 28, 2011 | 07:00 PM
dj-vega's Avatar
I started up the car, and is was idling for like and 30-45min, with some easy reving. The temp gauge was in the middle. like 50% of maximum. And is not getting any higher, even tho, the thermostat is a "winter" version. it opens at 90'Celsius/194*Farenheit. Thats what the last owner said to me. The heater inside the car works perfect. Really nice heat.
About the ABS system. There is two relays to the ABS system in the fuse box under the hood. I also found som fuses. But the when im driving it, and press the brake, it goes more to the bottom, that normal cars. And i also feel some resistance like the the abs system is working. Im really not sure about this. Ive just own the wehicle in like 3 days now. But i really enjoy driving that car.
I hope you understand the most of my writing. Being a norwegian, my english is not perfect, but im working on it. Better and better everyday.
Old May 28, 2011 | 07:50 PM
the fans will come on when the temp is high enough based on the PCMs programing
the abs is only in use the the van is out of control IE one wheel spinning faster then the other..
Old May 28, 2011 | 08:21 PM
dj-vega's Avatar
But arent the "ABS" light suposed to ligth on when you start up the car?
Its not doing that in my case...
Old May 30, 2011 | 11:50 AM
have a dealer run your vin see if it came with it or not.
AZ_Ron
Jun 17, 2012 07:42 AM
simonda
Jan 3, 2010 02:44 PM
scudinferno
Nov 5, 2009 10:52 AM
johno
Feb 21, 2008 02:32 PM
bigrobot
Jun 26, 2007 09:44 AM
