my chrysler grand voyager
Old Jun 19, 2012 | 11:35 AM
pienmashpaul's Avatar
Default my chrysler grand voyager
HI
I have a 2005 Chrysler grand voyager crd xs ltd engine size 3301 which has done 71,000 miles in march I had the car converted to lpg gas so it is now dual fuel petrol and gas. I started having trouble with the car in April when a engine warning light come on it showed the cam shaft sensor and when i tried to accelerate and revved the car over 3 the car would shudder and lose power. I got the garage to replace the cam shaft sensor and the car was fine for two weeks and then the engine warning light came on again showing the error as the oxygen sensors I also had the same problem with acceleration. The garage replaced the oxygen sensors and the engine warning light showed the error the camshaft sensors the garage the took the gear box out and inspected it and changed the timing belt but the car is still the same he is now asking me to get a starter ring gear as there maybe a slight crack in casing which he cannot see. The Garage is not trying a fast one as he has not charged me as he has not resolved the problem but i think he is running out of ideas I have also noticed recently that the engine is getting very hot. the only other thing that is wrong with the car is the automatic sliding door on the passenger side not working. and done the rev counter and speedo are going haywire and is not starting first time and the engine seems very hot even after short journeys I hope you can give me some advise
Old Nov 22, 2012 | 07:03 PM
keithsketchley's Avatar
I'd sure check into how the conversion was done, have to connect to the right wires - and does the computer need to know your fuel is different? How did the converter do that?
alexnz
Mar 17, 2015 03:06 AM
goggs
18
Oct 26, 2014 08:05 PM
afrance
9
Aug 11, 2008 03:44 PM
penelope pitstop
Dec 7, 2007 04:30 PM
siggie
Oct 28, 2007 12:58 PM
