Newbie needs rad fan help!!!!
Old Apr 10, 2011 | 03:47 AM
lexi's Avatar
Default Newbie needs rad fan help!!!!
Got my first GV after getting rid of my Grand Cherokee. I took the GV for a long drive to check temps because the guy who traded it in said that somethings not right with it because the fans dont kick in.
I have bridged the grey/dark green on the fan relay (under the airbox) and both fans work. The worrying thing is that the bridging wire (paper clip) got extremely hot. I would imagine the relay is shot but I dont want to replace if the heat created through the wiring causes heat because it could knacker the relay.
Any ideas would be of great use
Old Apr 10, 2011 | 06:38 AM
mgbmike's Avatar
From the 2000 FSM:
INSTALLATION
CAUTION: The relay mounting location is designed
to dissipate heat. Ensure the relay is properly
attached to prevent relay “thermal” shutdown and
relay damage, resulting in possible engine overheating.
I seem to remember reading somewhere you need to clean the relay mounting area and use a heat transfer paste between the relay and the mounting area before riveting the new one.
bfarroo
May 28, 2015 07:46 PM
ChryslerEl
Aug 22, 2013 05:00 PM
fr00t
Sep 21, 2012 11:41 PM
nickw23
Aug 26, 2012 03:46 PM
svttour
Sep 24, 2010 02:48 AM
