no duct control
Old Oct 28, 2010 | 12:36 PM
Yacky's Avatar
Default no duct control
05 T&C 39k miles dual zone HVAC stuck on panel vent, hot or cold settings. Looked over chryslertech posts and swapped known working motor with duct control motor, still not operating. Coolant level is at max and clean, both lines to heater core are warm with engine at operating temp. Self diagnostic revealed no codes or errors, can manually operate blend mechanism with motor removed. On lower (2) motors for temperature I got 4-9 volts signal, and on upper (1) duct motor <1 volt. Also possibly unrelated the temperature has randomly swung from cool to hot w/ or w/o AC on several times in 6 months. Any thoughts or ideas appreciated since winter is almost here!
Old Oct 28, 2010 | 10:00 PM
do u have a heat prob or a vent directional prob?
Old Oct 29, 2010 | 02:36 AM
Yacky's Avatar
duct control problem.
Old Oct 29, 2010 | 08:03 AM
Yacky's Avatar
The heat & ac are ok but the floor, vent, and defrost selector is not working.
Old Oct 29, 2010 | 10:58 PM
put that volt meter on the wires for the mode door motor then move the **** does it change voltage?
Old Oct 29, 2010 | 11:59 PM
Yacky's Avatar
Little to no volts.
Old Oct 30, 2010 | 02:30 PM
possible bad ac control head or wire issue
Old Oct 30, 2010 | 03:15 PM
Yacky's Avatar
Where's the control head and can it be tested?
Old Oct 30, 2010 | 10:33 PM
the control head is the thing u turn the ***** on and u were testing it already if U dont have voltage coming out of it well then there ya go
Old Nov 3, 2010 | 05:02 PM
Yacky's Avatar
Default update
Got some time to further check van out. With center console removed and control head disassembled things appeared fine. With my fingers crossed I began reassembly. Believe it or not the controls worked again! Im leaning towards a loose connector in dash as the cause of malfunction, or dumb luck. That saved me about $90+ for a replacement control head online used or $$$ at a dealership. This is a valuable site, I hope to help others sometime, and Id like to thank chryslertech for his posts and knowledge.
billbon8
Jan 1, 2010 06:49 PM
Buckjohnsk
Mar 12, 2008 03:11 PM
Makala
Jun 14, 2007 11:19 PM
sulup
Other
Jan 24, 2006 01:54 PM
