no heat
Old Nov 24, 2008 | 02:28 AM
dhhbomb's Avatar
Default no heat
well i have never used heater since i live in southern cali but for some resason today was especially cold went to put the heater on put it on full blast and there was almost no heat coming from the front and the rear was completley cold and please dont say i had it on wrong since i tried all other possible setttings and still no heat only a little in the front and have no idea what it could be the ac works fine any information would be greatly apprciataed its one a 01 t&c limited
Old Nov 24, 2008 | 11:58 PM
dodgetech1's Avatar
Default RE: no heat
First I would check coolant level. Low coolant level means there is air in the system and air is very very very bad at transfering heat. I would almost bet money that your coolant system is low and that you have a leak somewhere. being an 01 t&c i would guess that its leaking from the water pump. have seen this a couple of times. There was also a recall though for the underbody heater hoses getting replaced due to corrosion from road salt ect. Check coolant level and let us know.
Old Nov 26, 2008 | 01:13 AM
dhhbomb's Avatar
Default RE: no heat
well i checked the coolant level wasnt really low only added like 12 oz but looked underneath for corrosion on hoses nothing and after running for a while i checked for leaks found none i was only able to get heat after car was running for like 20 mins and got some decent heat but not what i would say standard any thing else i should check
DJ SHORTY
Jan 14, 2020 05:49 PM
reyesraiders1
Nov 11, 2010 09:39 PM
davet
Dec 19, 2007 04:18 PM
stunod2002
Dec 15, 2006 03:27 PM
Petre
Dec 11, 2006 01:44 PM
