no low beam & other electrical issues
Old Sep 13, 2008 | 05:27 PM
mutation's Avatar
Default no low beam & other electrical issues
2002 T&C LXi: The right-side low beam is out on my car. I replaced the bulb - still out. I switched the bulbs L for R - right side still out. High beams both OK. I unplugged the wiring harness from the bulb and from the IPM; there was no continuity from either the low or high beam circuits (maybe this can't be done or I'm doing it wrong).
Is this a Front Control Module issue? There are other electrical issues:
1 - rear washer doesn't work, replaced pump, still inoperable.
2 - Backlighting of most switches is gone. This started with 1 then 2 bulbs in the AC selector, then they all went out in the center console.
3 - Foglights stopped working.
4 - Overhead console maplights refused to turn off. When this first started I did get them to turn off once, but they were on when I returned to the car so I removed the bulbs.
State inspection is coming up, so I need the lo-beams. HELP!
Old Sep 14, 2008 | 05:44 PM
Default RE: no low beam & other electrical issues
possible front controller or IPM itself
jsgove1959
Dec 30, 2014 02:30 PM
Vcor71
Oct 21, 2014 12:03 PM
lmekic06
Nov 13, 2011 03:52 PM
chrisso
May 2, 2011 01:58 PM
ajs42548
Jan 19, 2011 01:45 PM
