No power to low beam headlamp (driver sider)
Old Apr 4, 2024 | 09:44 AM
wsand23's Avatar
Angry No power to low beam headlamp (driver sider)
2021 Voyager LXI: Driver side low beam headlamp went out so I replaced the bulb (purchased new) which also did not work. Voltage test determined there is no power to the headlamp input (and original bulb tests good). All fuses are intact, all wiring appears to be clean and intact, all the other headlamps work (low beam passenger side, high beam both sides, daytime running both sides, and orange parking both sides). From the fuse box diagram I cannot determine which relay the exterior lights run through, so have not tested that. I am stumped!! Any suggestions?
thakilla
Oct 19, 2019 08:25 AM
Pappy118
Dec 4, 2011 11:50 AM
lmekic06
Nov 13, 2011 03:52 PM
ajs42548
Jan 19, 2011 01:45 PM
scott04
Dec 16, 2009 08:41 PM
