passenger low beam out
Old Oct 17, 2019 | 12:09 AM
thakilla's Avatar
Default passenger low beam out
Hi all. new member here. i have an 07 touring that has had many issues. most have been resolved, but i do have the pasenger side low beam headlight out. i replaced the bulb to no avail. the high beams work fine. i voltage tested the connector and found the high beam to chassis gnd was 12.8vdc while the low beam to gnd was only 6.4vdc. has anyone ever had this happen? my research has led me to the TIPM (fuse box) connector C5 and C7. any help would be appreciated.
Old Oct 19, 2019 | 08:25 AM
djetelina's Avatar
The older Pacs (including my 05) had a factory recall on the wiring. When new, my Pac's headlights went out, a quick trip to the dealer got the beams back on with the help of some upgraded wires. Would think that recall was fixed by 2007.
The headlights are switched by the Integrated Power Module via solid state drivers. Perhaps the IPM is the issue? Wiring for the 2005-06 can be found here..
vgarfield
Dec 18, 2013 11:19 AM
Pappy118
Dec 4, 2011 11:50 AM
lmekic06
Nov 13, 2011 03:52 PM
ajs42548
Jan 19, 2011 01:45 PM
wig6516
Mar 15, 2008 10:14 PM
