NO REVERSE!! 3.3 litre Chrysler Grand Voyager Automatic Transsmission
Old Dec 21, 2014 | 09:20 AM
Diezeltruck's Avatar
Default NO REVERSE!! 3.3 litre Chrysler Grand Voyager Automatic Transsmission
I was reversing my 1999 3.3 litre Chrysler Grand Voyager up a steep inclined driveway when suddenly it lost transmission.
I immediately stopped the car and left it for a few hours thinking it had just overheated.
It drives forward with NO problems but later that same day when I came to park the vehicle it would not move in reverse gear????
What have I done to it and is there anywhere local to Sheffield that can fix it?
and how much is this likely to cost?
I have not checked the transmission fluid level but assume that if it still goes forward then that's not the issue
Any help/advise on this much appreciated.
thanks
Diezel
Old Dec 21, 2014 | 09:36 AM
Please ignore the Sheffield part of the post!!! Can't find how to edit the post to remove that bit.
I have checked the level of transmission fluid and the dip stick shows it is not low on fluid!!!
Is it likely to be just a straight-forward linkage problem or faulty solenoid??? and if so, is this a easy repair?
Old Jul 23, 2023 | 04:16 AM
Nosferatu's Avatar
Exclamation
Hi chap,
Did you ever resolve the problem?
I have a 2008 Grand Voyager 2.8. All forwards gears are absolutely sound and work/shift fine.
Soon as I go into reverse, the gear locates as it should absoultely no problem, then the revs will not pick up.. the vehicle sits there.. not reving almost trying not to die instead.... if i bump to neutral build the revs, then slide into reverse keeping revs built. It will then go, but if i ease off the throttle the revs die slowly down and the car will just sit again struggling to reverse and very very low revs, even flat to the floor.. no revs!
musicman4u2c
Mar 10, 2019 08:19 PM
thegrandvoyager2
Feb 12, 2019 10:33 PM
thecomputerkid
12
Oct 14, 2015 03:49 PM
gkaucher
Oct 2, 2010 02:39 PM
tonywhite
Aug 26, 2008 10:50 AM
