Noise from Gearbox Area
Old Dec 25, 2015 | 02:31 PM
John Norrish's Avatar
Default Noise from Gearbox Area
Severe clanky rattle from gearbox area, goes when clutch is depressed, I hope it is the thrust bearing but never heard a noise as bad as this before and I used to work with commercials, also when driving and noise bounces back off a wall the sound is there, I'm hoping it isnt the box, oil was changed 6 months ago, is this a common noise??
2003 2.5CRD
Old Dec 26, 2015 | 04:25 AM
matgriff's Avatar
Hi
I had a 2001 voyager 2.5CRD from new until two months ago (manual) we did 175,000 miles in it.
It had the same noise from the gearbox as you describe for pretty much as long as I can remember. Harsh kind of bearing noise with the clutch out in neutral and then quiet with the clutch pushed in...
I changed the gearbox oil a couple of times during it's lifetime it never changed the noise. Of course I can't say how bad your's is compared to mine, but it was definitely noticeable.
I do have to say that the eventual demise of the car was failure of the gearbox or diff bearings tho.. but after 175K I couldn't complain.
By the way, I've owned and rebuilt Kawasaki motorbikes for years now, they are exactly the same, clutch rumble in neutral that goes away when the clutch is in.
Mat
Old Dec 26, 2015 | 04:47 AM
Hi thanks for the reply, this has only done 86k and believe me its noisy, when I get back to the UK I will have my Son and a two post ramp so I will take the box out (Rather my son will lol) then we can have a poke round,
Old Dec 26, 2015 | 05:56 AM
matgriff's Avatar
I guess the noise is from the primary shaft bearing or similar. I had two new clutches (complete 3 part) in my voyager and it didn't make any difference to the noise, so it's not the clutch thrust bearing.. that would make a noise when you pressed the clutch in.
Mat
soulpoehl
May 9, 2014 10:12 PM
Wayne34UK
Mar 17, 2011 04:07 PM
Darren79
Feb 6, 2011 11:42 AM
TrueBlueGTO
Feb 15, 2005 02:34 AM
redriderbob
Dec 27, 2004 05:58 PM
