O2 sensor
Old Nov 25, 2014 | 05:43 AM
Bee's Avatar
Bee
Default O2 sensor
Hi Guys
My car is a 2.8td and is giving me an engine code P0130. O2 sensor.
Has anyone got a part number for it. Where can i get one.
Old Nov 25, 2014 | 06:54 AM
TimmyTim's Avatar
UK Distributor for VM Motori Diesel Engines & Parts
Contact these guys for the cheapest Genuine VM Motori (Chrysler ) parts. Take a look on Ebay as great deals some times.
Old Nov 25, 2014 | 10:33 AM
tfb's Avatar
tfb
are you sure it wasn't P1130?
the 2.8 diesel engines don't have 02 sensors, but are prone to throwing 1130 codes.
Regards
Richard
Old Nov 26, 2014 | 01:35 AM
Bee's Avatar
Bee
Hi guys
Yes I got it wrong it was P1130. I've ordered an O2 sensor from RBS handel in Germany 60euros.
Old Nov 26, 2014 | 01:49 AM
Bee's Avatar
Bee
Hi Richard.
Any idea what makes them throw the P1130 codes.
I have read on here it mite be the crank position sensor or cam sensor.
Old Nov 26, 2014 | 07:05 AM
tfb's Avatar
tfb
P1130 is fuel rail pressure.
Most common is air getting into the fuel through the filter housing, occasionally due to to leaking injectors, rarely the fuel pressure safety valve leaking and has been known to be wiring.
Is it cutting out under hard acceleration?
Regards
Richard
Old Nov 26, 2014 | 02:58 PM
Bee's Avatar
Bee
Hi Richard.
Thanks for the reply. It's had a new fuel filter housing.
it's not cutting out under hard acceleration. just lumpy idling.
Adrian
Old Nov 28, 2014 | 04:38 AM
tfb's Avatar
tfb
lumpy idling would tend to point to injectors, but you will need testing first. Swapping parts out randomly is not the most efficient way of fixing things.
I'd start by a leakback test on the injectors and replace any with excessive leak back. Next look at the fuel rail pressure on an oscilloscope to check for value and stability.
regards
Richard
Old Nov 28, 2014 | 01:06 PM
Bee's Avatar
Bee
Thanks tbf.
That sounds great the leakback test can a local garage do it?
Old Nov 28, 2014 | 02:09 PM
There's an on [on the car] test and an off [off the car] test, many garages will have
one of these one of these
, this is the on test.
