Odd water problem on Grand Voyager 3.3
Old Apr 14, 2011 | 08:44 AM
stewartsoftware's Avatar
Default Odd water problem on Grand Voyager 3.3
This is a odd problem, I have a 3.3 2002 Grand Voyager, and it NEVER over heats but when I look into the radiator (Take the cap off) it looks half full ! (You can see the internal fins if you look inside), it takes very little water to bring it up to the top of the cap, and it bubbles when you refill it (With the engine off).
The expansion tank is normal between min and max.
Anything to worry about or normal ?
Old Apr 14, 2011 | 09:20 PM
normal
Old Apr 15, 2011 | 02:55 PM
GrahamLemon's Avatar
Any brown deposits around the top of the rad? If so, you might have a similar leak to mine. Also, a good diagnostic test is to see if you have heat coming into the cabin. If you do, all OK, but if it blows cold all the time, even if the engine water temp is warm, there's most likely a leak.
New (non-Chrysler) rad cost me £280 fitted, no more problems.
HTH
Cheers
GL.
Old Apr 16, 2011 | 05:17 AM
HTH
Cheers
GL.
Got a pressure test done and all okay, no brown deposits and heater works fine, so cross fingers its all okay.
Old Apr 19, 2011 | 03:41 PM
Glad to hear!
scooby
Oct 8, 2012 08:38 PM
dmbeale
15
Nov 24, 2010 06:26 PM
captain catfish
Oct 2, 2010 04:32 PM
musicfreak2195
Jul 7, 2009 02:23 PM
dcm1971
Mar 13, 2009 02:43 AM
