Opps!! smoke from under the car
Hi guys.I have a 2.5CDR Grang Voyager on a 2001 plate. I have noticed that when I parked the car today there was smoke coming from underneaththe car, when I looked it seemed to be coming from a pipe or venton theleft hand side,
PS this also happend a few weeks ago and im not sure if it is a coinsidense but on both ocasions i had the heater on.
I drove the car home and it was fine when i got home 10 mins later (heater off)
Any Ideas???
Any Ideas???
ORIGINAL: TheNostradamus
Any Ideas???
Any Ideas???
Hi
Im new owner of Chrysler Voyager. I did experience this as well. You find in the operating information book on page87 all you need to know.I must say when I saw this fumes made me thing that my car start burning!!!. False allarm!!!! KInd regards Ninny
ORIGINAL: ninny
Hi
Hi
I dont have the operating book at the moment, so can i ask, is the aux heater diesel or electric and how do I stop the smoke being so bad/thick, i need to ask as the weather is getting colder over here and i need to do some driving..
Apprecciated...
I don't think you have any control other than whether it's going to switch itself on or not. Basically, if it's cold and you switch the heater to hot, then the auxilliary heater will switch on and stay on for a few minutes, even if you turn the engine off. It seems to me that the way to stop it kicking in is to not quite switch the heater to hot until the engine has warmed up.
Hi It doesn’t come on when it’s over 15c outsideor when less then 1/8 of a tank of fuel or when the inside temp is higher then the set point. Other then that it will run for 5 minutes on every run
Apprecciated...
Apprecciated...
i haven't seen that system at crysler vehicles but I presume it's a normal webasto heater. they usualy make a lot of smoke when there is not enough air.
ORIGINAL: mrfixit454
Sorry to get off topic, those with the Diesels, what mileage do you get. Was not aware that chrysler made these w/ diesel.
Thanks (again) Merlin for explaining more accurately the auxiliary heater - do you know how much fuel it burns in 5 minutes? Also, any idea where the intake filter is? Sounds like something I need to check.
