P0132 fault
Old Jan 26, 2018 | 01:08 AM
Krzysztofk's Avatar
Default P0132 fault
Hi, after oxygen sensor change, a fault P0132 is shown, the engine check service lights up. When I erase the fault, it wont light up when it use. It will light up after not being started overnight. A geniune chrysler oxygen sensor is fitted, and is good for sure. What else could be causing this fault?
Old Jan 26, 2018 | 08:43 AM
Krzysztofk's Avatar
I have the same problem the fault p0132 after replacing the oxygen sensor, have you resolved it?
Old Jan 26, 2018 | 08:52 AM
Vonhofinvule's Avatar
This can sometimes happen if there is corrosion in the harness plug. Try unplugging and plugging the new sensor back in several times, this sometimes works. Also check the wirering to ensure nothing has been damaged.
momzilla
Jan 26, 2018 08:47 AM
drogahn
Aug 23, 2011 08:26 AM
stewartsoftware
Apr 17, 2011 03:22 PM
danielrp
Mar 29, 2008 04:26 PM
creepycarrie
Other
Dec 12, 2005 03:27 PM
