P0135 code
Old Jul 16, 2014 | 10:43 PM
bcupac53's Avatar
Default P0135 code
hello all,
I have a 2004 town and country, 3.8, check engine light came on, checked the code, it gave me a code that said my upstream o2 sensor was bad, changed it out, went a couple days, the light came back on, then it gave me this code, P0135, saying the upstream o2 sensor(cylinder bank 1) heater failure, what the heck is heater failure? any help would be appreciated. thanks
Old Jul 18, 2014 | 11:25 PM
Raptor 07's Avatar
There's a heater built into each O2 sensor to quickly bring it up to the operating temp (around 600F) right after you start. Cuts down on pollution. You may have installed a bad sensor, you may have an open wire from the sensor to the PCM or the PCM may be bad. Most likely the sensor heater died. Did you use NKG or Denso? Bosch has a bad rep with these vans.
Old Jul 19, 2014 | 11:20 AM
Prob used a BOSH o2 sensor
Old Nov 1, 2014 | 08:56 PM
Jean Berghuijs's Avatar
Default Tech bulletin ERROR CODE P0032 P0315
After a lot of research I think I found the problem.
I found a tech bulletin indicating that after July 09, 2004
O2 sensor resistance (ohms) was changed.
Before 2-4 ohms NTK 23568
After 7-10 ohms NTK 23566
(Initial fault was P0032 indicating a problem with the upstream O2 sensor.)
Needing replacement.
You can measure the resistance between the black wires on the sensor with an ohmmeter. (The heating coil)
I hope this helps somebody else.
Old Nov 2, 2014 | 03:50 AM
TimmyTim's Avatar
Nice find ^^^^^^
Voyager One
Jun 12, 2014 09:24 AM
SpudlerT+CTouring
Oct 19, 2011 02:10 PM
kesleke
Dec 24, 2010 09:07 AM
georgejzeck
Mar 15, 2010 12:29 AM
dc_tr
11
Jan 3, 2010 05:39 PM
