p100 code
Old Nov 20, 2012 | 04:47 AM
joker2cv's Avatar
Check the EGR valve too
Old Nov 20, 2012 | 06:35 AM
bryan307's Avatar
just ordered a new one off ebay will keep you informed as to the outcome
Old Nov 22, 2012 | 01:30 AM
bryan307's Avatar
just took delivery of new maf sensor is it a case of just replace or do i need to clear the code before it will work,if so how do you clear them?
Thanks for all your help everyone
Old Nov 22, 2012 | 04:52 AM
joker2cv's Avatar
It will work anyway.
Perhaps the code will be cleared itself, otherwise you have to clear it with a OBD scan tool.
Let me know!
Old Nov 22, 2012 | 05:14 AM
  #15
bryan307's Avatar
still smoking looks like my time owning a voyager is about to come to an end unless it just needs a good clear out down the highway
Old Nov 22, 2012 | 05:33 AM
  #16
joker2cv's Avatar
Should be a stuck EGR valve. Try to disconnect its vacuum line (right side of the intake mainfold).
When it smokes? At idle or during normal drive?
Old Nov 22, 2012 | 03:14 PM
  #17
bryan307's Avatar
idle a little but when driving quite a lot
Old Nov 23, 2012 | 04:17 PM
  #18
Default Smoking Engine..
Hi yet again,
I stuck or knackered EGR valve in other cars either shuts it down of puts it in limp home mode...
Smoking engines can be caused by Crankcase pressure build up due to blocked vent valve.
Is this a problem with this engine, on irregular oil changes..
Goggs...
Old Nov 24, 2012 | 12:54 PM
  #19
bryan307's Avatar
egr valve been blanked off all breathers been cleared getting obd reader in the week
Old Nov 24, 2012 | 01:26 PM
  #20
joker2cv's Avatar
At this point a bad injector could be your culprit...
